Help ScreenCaptureService
droid newb
Every now and then I get a text popup on my screen that reads, "screen capture sent to SD card" and sure enough when I look on my SD card there will be a fuzzy, grainy screen capture in a folder. I don't know how this happens or why they're so crappy looking, but if this is something I can use and get clean screen caps I'd love to use it!
Anyway, at the Sprint store the techiest of the techs said they had no idea how this happens. I just looked into what's running on my phone and there is something called ScreenCaptureService. Does anyone know what this is?
My phone is not rooted and I did not install this...it is on the phone right out of the box.
Path: Settings >> Applications >> Running Services
TIA!
Mine has done this before too! The exact way you described has happened to me. I found the ScreenCaptureService in my batterysaver program.
I would assume since this phone is capable of screen capture, we just need a program to tap into that!
I use Juice Defender...is that what you use?
Actually I'm using Improved Battery Saver2. I've used it for a month now and here's the results.
BEFORE:
Unplugged at 7am
30% Charge by 4pm
(workday)
AFTER:
Unplugged at 7am
70% Charge by 4pm
(workday)
AGBandit, is that the full name of that app? I can't find it in the marketplace, and based on your results, I'd like to try it.
this SAME exact thing happens to me ! just all of a sudden tha screencapture saves to sd card thingy pops up ! i dont know WHAT it is that im pressing to make this happen and my pixcs are crappy and grainy as well !
It's been rumored that it was put there to take a picture of a crash when something fails on the phone but no one knows for sure...the screen captures all seem useless as far as images go.
