Screenshot help
  • Start date Start date
If your phone is rooted you can install an app like Screenshot:
https://play.google.com/store/apps/details?id=com.geeksoft.screenshot
For a non rooted phone you can buy this app:
https://play.google.com/store/apps/details?id=com.edwardkim.android.screenshotitfullnoroot
You can also use Android SDK:
How To Take Screenshots In Android Using Android SDK
As a side note:
The phone doesn't have Android 4.0, but when you get a cell phone with Android 4.0 or later you can press and hold the Volume Down and Power buttons at the same time for a screenshot.
