[script] change fonts
suhel28
Make a folder named FONTS in your sdcard.
Put any font file .ttf in it (only one at a time)
download and extract the script in the root of your sdcard
Run the Script in terminal emulator ( ATTACHED) on your phone or in CMD on PC
If you are using CMD first type
adb shell and than type the below code
su
cd /sdcard
sh fonts.sh
your phone will reboot after running this script to make changes.
This script : -
  1. will rename the font placed in the fonts folder
  2. will replace:-) the fonts
  3. will create backup of your original font in your sdcard.
Cheers :)
EDIT : Original fonts attached just incase you want to go back
Yes :D You used too many echos a think :D But good work anyway :) I appreciate that you keep such a good work :)
The real headache was to pick any file name and change them to Droidsans... those 4lines of script made me go through so many forums of Linux... I wanted a script in which people would had to do minimal work.. I guess I'm successful.. did you try it yet?
PS - I'll never buy the Linux OS
Yes ofc I have tried it :) Works good :/ but it has to be the font problem that it makes some kind of squares in stead of some letters :) And for example if the icon title is too long some letters are missing :/ I have to find better font :D
Definite success :)
Linux is open source :) You don't have to buy it lol :D
Definite success :)
I know its open source mate..
My mode of context was I'll never have it as my working OS.. :-)
I'm using "black chancery" as my font for now :-)
Me too :) I have to work on it at school ... RedHat distro sux hard :D
Nice font but I'm kinda minimalist :) So I'm looking for something smooth and simple ;)
Use the default font lol...
Why not the famous times new roman
Edit: search for TIMELESS over the internet.. very simple and lovely fonts
Well there are many hotspots almost everywhere I go :) At home, at school even in pubs :) and almost all of my friends got wi-fi networks at home :)
So no problem with connection ^^
