Apps Scroll pictures horizontally - how to?
ac4android
Hi.
I'd like to scroll horizontally pictures of a dozen pizzas and pasta on menu
Can you please point me in the right direction.
Yes and thx, that's in the direction I am heading.
If I have 30-40 images, is it the best thing to put them inside drawables though? But then, where else could I put them where they will have minimal impact on client Android?
And what if I have new images? Should I to put them in database for download to SQLite?
Well if you want to put them in a scrolling list then I think you will have to hold the images in memory as drawables. How big are they?
How do I create a folder under res/layout or res/mipmap to hold .png-images for a horizontally scrollable images? Must be do-able, I see a lot of that on twitter.com
I've tried under drawable, mipmap and layout. None would accept a sub-dir. I need to have something like the ic_launcher to launch a series of images
Also, I need to have a "<" and ">" to left and right to he;p user scroll the images.
UPDATE:
Yes, I can create the sub-folder under Project instead of Android.
But how do I load several images into the subfolder? The Android method allows for one and only one image:
Code:
imageView.setImageBitmap(BitmapFactory.decodeResource(getResources(), R.drawable.ic_launcher));
In the above example, Android when and launched the images in ic_launcher, each in a different subdir and each with a different resolution, one after the other
I just want to create a sub-dir with a list of .png images that I can display and scroll, this is an example:
UPDATE: Thanks. Got it working :)
