Help SD card connection issues
Occasionally my Samsung S4 phone is telling me it's lost connection with the SD card. If I take it out and clean it up with a cotton swab and alcohol
it works again for a few days. Likely its the connection rather than dirt.
Wondering if there is anything easy enough that I can do to fix this.
Try another card, if the problem persists the connectors on your phone's mainboard might be bad. Otherwise it's on the card.
