Help SD card corrupted/couldn't move apps
The thing is I bought a Kingston 16gb class 10 as card but I'm experiencing some technical issues:
When I installed it, in storage it said it was unsupported and I would have to format it. But after formatting it(as internal storage) i tried to move some apps and i ALWAYS get the message 'couldn't move app, internal error'
If I restart (turn off and then on) the phone it appears like 'corrupted' and I need to start over.
Also I tried the 'move now' choice when I formatted it again and appears the message'couldn't move, not enough space' so this is ridiculous. Any help, please?
If you formatted it as internal, where are you trying to move the apps? They're already where they should be
I'm trying to move the apps from the internal shared storage( the phone) to the sd card.
As it's a new micro-SD, check its integrity with SD Insight, ensure it's not a fake or duff. Where did you buy it, e.g. cheap online like Ebay?
https://play.google.com/store/apps/details?id=com.humanlogic.sdi
What you're describing with corruption and things not working as they should, it could be a counterfeit Kingston micro-SD.
My device it's incompatible with that app, but I'll have a talk with the seller. I bought it in a new shop near my school so maybe they got scammed.
Do you have a computer with SD reader?Try the SD in that, and see if that can read and write data, which should prove if it is the phone or SD problem.
I have tried it in the PC and it works. What do I need to do in order to make it work in the phone?
Also tried formatting it as portable storage and it works, the problems appears when I select the option that I want( internal storage)
