Buckeye101
Member
So my SD card says its damaged and wants me to format it after I had reboot it from the recovery screen, I did that and then went back into my recovery later the same day and gave me the same result. Thinking that it was just the SD card I went out and bought another one the same week. When I sat down and reboot it with the new SD card from the recovery screen cause I was backing my current ROM up. I got the same result as before . Is the problem my phone? Or do I need to reroot my decive? Need some help please!!!
