Depends what you mean by all, but I'm guessing you mean app data (and maybe installed apps).
In which case, you can't (*). You can back them up to SD, e.g. using Helium if unrooted, Titanium Backup if rooted, but they won't run from there - it would purely be a backup. Fine if you want to move stuff to another phone, but not if you are trying to make more space on the current one. If you are still on Android 2.2 or 2.3 you can move some apps to SD, but that's it. On Android 4 that is no longer possible.
(*)Actually there are ways, but you need to have partitioned you card and to be rooted and running particular custom ROMs, or ROMs modified in particular ways. Even then it is less stable/reliable in my opinion. Since I don't know LG handsets I can't advise on how to do this.
