Hello,
I hope the following will be detailed enough for you to understand, but apologies in advance if it isn't. I'm new to this forum.
I just upgraded my T-Mobile SGS2 to ICS. Looking at the new features, I enabled the encryption of the sd card. However, now whenever I restart my phone, the card is disabled for some time while it goes through the encryption process, and the battery is severely drained. Also the phone gets very hot. I can no longer use the face unlock option, and I'm getting fed up with having to put in a pin constantly.
I can't find any way of reversing this process. Does anyone know what I should do?
Thanks
Thanks
