Root Sd card folders not showing up on pc
MustangLife
Hey all so for some reason my factory installed folders on the external sd card arent showing up on pc or the files. If i create a folder and move files in that folder it shows up fine on my pc. Tried 3 different cards and all the same. Also tried another pc and same result. No mods have been made or app installs.
Running debloated and deodexed kitkat 4.4 from superr. About 6 weeks ago i made the jump from link2sd to link2sd plus which i gotta say is the best bang for the buck there is. Even better than greenify
