Sd card for Samsung Galaxy A20S
Rgarner
Android Expert
I'm in the market. Is it true it can handle up to 512 GB? I saw some listed online for maybe $13, which seems unreaiistic. What's the best source, maybe local?
just like with anything electronics, you get what you pay for. cheap cards can fail or get corrupted easily. so use at your own risk and always back things up regularly if you do go that route.
I went to Target and got a 64 GB for now. It was $18.99 and tax. I got it in the tray fine and the A20S recognizes it. On the pulldown it says Tap here to transfer media files, but it doesn't do that. I cannot figure out how to transfer them. In My Files it shows the files I want to move, but when I try it claims that destination and source are the same.
I looked it up online and found this from Verizon. It seems straightforward enough, except that the step involving move is impossible because it isn't there. The only option is details and that doesn't help. How the heck do I move these files?
There you go. When I try to move from internal storage to sd, I do not have the option. It says the destination and source are the same. What is wrong with it?
I must have looked at all the categories by now. I checked out online help too and came up with nothing useful in this case. Why doesn't it work?
