sd card gone
Lineman69
Member
i have my sd card in my motorola xt701 it worked fine. now it is saying there is no sd card in the unit.
i have reinserted it and it just keeps saying to sd card.
Few potential problems:
1. you have unplugged it or something without unmounting it properly. FIX: Reformat the card
2. Some error has occured on the card. FIX: Reformat the card
3. the card went batty. FIX: throw it out and buy a new one.
ok i fixed that it was the unmounting problem card is found. now the wireless network and the 3g wont work since i fixed the card. take the card out reboot and the wireless works. put the card in it sees the card but then turns the network off again
ok i unmounted then without card booted up then once booted and the network work placed the card in ....tada. is that how you always have to do it??
Maybe i should change this thread's title to skyfire non compatible websites because so far aside from hulu based websites, I have been able to go on any website that have flash video. This browser is awesome.
Hello,
I m Boazdexter. Today I use this forum first. I learn very much from your forum. Please give me more guidance related to sd card. How is it useful? I am very happy after using this forum.
Thank You.
________________________________________
Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups seo pecialist
