V
Vueoy
Guest
Im very very sorry if this sort of thing has been posted before, but I need help as soon as possible! I'll try and explain my situation as best as I can.
So I'm not the most android/tech savvy person in the world. I recently bought the LG Optimus F6 from MetroPCS because it was a pretty good price for a good looking phone. Unfortunately (as those familiar with the device will understand) the internal storage is TINY. I bought a 32 GB SD card and it has worked great for all music storage and whatever, but Google Play continued to install apps to my Internal SD which there wasnt enough room for. To get apps onto my SD card, I read that I had to root my device, so I did and it went well!
However, I had to create an SD card partition and this is where it gets messy. I made the partition, and I messed up at some point because now there's two partitions or something?? and it's really weird and I just want to make Link2SD install apps onto my External 32 GB SD card but ITS NOT WORKING AAAAA. I try to download apps from the google play store with the partitions and the Link2SD set to autolink things to my SD but it still says insufficient storage. I need to be able to install apps onto my SD card and I'll do anything I have to to make that work. Please help soon, if you can!
Here's a screenshot of my storage info via Link2SD:
http<dot>//i<dot>imgur<dot>com/mnBakEs<dot>png
(^ to get past spam filters, sorry mods!)
Am I helpable? D:
However, I had to create an SD card partition and this is where it gets messy. I made the partition, and I messed up at some point because now there's two partitions or something?? and it's really weird and I just want to make Link2SD install apps onto my External 32 GB SD card but ITS NOT WORKING AAAAA. I try to download apps from the google play store with the partitions and the Link2SD set to autolink things to my SD but it still says insufficient storage. I need to be able to install apps onto my SD card and I'll do anything I have to to make that work. Please help soon, if you can!Here's a screenshot of my storage info via Link2SD:
Am I helpable? D:
