sd card in samsung galaxy s2 has stopped being recognised
  • Start date Start date
A
Android Question
Guest
The sd card was fine ive had my phone 3months never removed it then in started going very slow and my sd card was no longer being read what can I do? I have removed the card and put back in but had no joy thank you
The first thing I would do is try another card. Borrow one from a friend, or find a cheap one to try. Whatever works for you, but this will help determine what the problem is. If the other card works, then your sd-card probably stopped working. You could try formatting it in a PC but you will want to make sure to back up all the sd card contents to the computer before formatting, otherwise all of it's contents will be deleted.
If a second sd card doesn't work either, it is likely a hardware issue with the phone and will probably need to be repaired or replaced by your carrier or the manufacturer depending on what kind of warranty the device is under.
