You can TRY a data recovery program on your computer. Remove the SD card and attach it to the PC using an adapter. With any luck, the data recovery program can recover SOME of your pictures.
And as Zapjb indicated, you never want to go cheap on memory cards. Make sure you buy legitimate brands like Sandisk or others with a good reputation. Fake SD cards are cheap but, as stated, have a terrible failure rate. Good luck!
When I spoke of counterfeits I mean the ones that state false capacity. They will state say a 32GB capacity through properties in a PC & details in Android. But really they're 2GB cards or less. So they keep on writing over & deleting "stored" data to seem like they're working.
