Hello. You will want to get a file manager from the play store. There are many free managers that work great. I use Astro File Manager but it is only one of many. Once you have the manager installed, you can easily move your music from internal phone storage to your SD card. You will find your tunes in a folder called Music. You will want to create a Music folder on your SD card to place your moved tunes. I hope this helps.
