Sorraia3
Earlier today I tried to go into my Dolphin Browser and it wouldn't launch. Then I tried AppsFire and ES File Explorer... none would launch. I went into Settings>Applications>Manager and it just hung on computing. I tried to plug in the phone to the pc and it no longer recognized it. I tried to unmount the SD card from in the phone and it just froze then force closed the SD card app. I have tried reboots and shut downs and removing, replacing the card... nothing... NO apps that are on the SD card will work, but the phone mounts the SD card every time. So it knows it is there, it just won't read it. I can't install/uninstall anything. I can pop the card in the pc and see everything on it. I can open the files and view it all. I have copied all of it the pc and was going to format it in the phone but it won't unmount it to let me.
Sounds like the SD card is shot right? Here's the weird bit...
Put the sd card into another MT4G... it found and mounted it fine. It let me unmount it and format lit up. So now I'm thinking it is the phone so I pop it out and put it back in my phone... same issues. Put the other phones card back in it and now that phone is doing the same thing!!! Whatever was wrong transfered from the SD card to that phone! Now I have 2 MT4Gs that won't launch apps that are on the SD card. all apps on the phone themselves still work... for now anyway. Could this be some kind of virus or malware? How can I backup the stuff that is on the phone itself to try a factory reset?
Has anyone encountered anything like this before? It really seems like whatever is wrong is contagious and passed to the other phone! Please Please help! We have so much stuff on these phones! The SD cards are backed up but I can't figure out how to backup all the stuff on the phones.
Thank you for any and all help!
Jen
Jen
