Hi folks,
I've been using my HTC Desire on Orange for less than a week now, and the above message shows up in the top bar persistently now.
I'm using a 32GB Kingston micro SD card, and have formatted it in the phone and on XP SP3 numerous times. Error checking it under XP temporarily fixes it and allows writing, but then it comes back again.
It does not seem to like music being transferred over, I tried syncing with an iTunes playlist through HTC Sync 3, and using doubleTwist but either way the music transfers, is playable but the message shows in the top bar all the time.
This prevents me from installing apps to the card, using the camera and a host of other things.
Any ideas on a permanent fix? Thanks!
Edit: using 2.2 (Build 2.10.405.2) OTA from Orange.
