muffinn Lurker Jul 15, 2017 #1 I gave access in storage to my SD card. I have moved apps to it which work. It no longer shows in ES File Manager home screen Any ideas?
M Member 1919122 Guest Jul 15, 2017 #2 Maybe the SD card is dead? Can you navigate to it using a different file explorer? ES is not the greatest and sends your info to China, btw...
muffinn Lurker Jul 15, 2017 #3 I don't think it's dead as the apps work I've moved there. Can you recommend a better ES equivalent? Cheers
M Member 1919122 Guest Jul 15, 2017 #4 I use solid explorer from the play store. Install SD insight also and see what it says about your SD card while you're at it
