Help SD Card Notifications...Bug?
Hanadarko
On my brand new Razr (24hrs old!) - I have noticed that when the phone boots and the SD card is mounted, there is an Audible sound "DROID" - and its annoying.
(Now, I am not talking about the mechanical sound/video that fires up when the phone boots)
In Sound Settings I find a section called "SD Card Notifications".
You can turn that off or on and here is the odd part.....
If I turn it ON, it will use whatever I have the "Notification Ringtone" set at.
If I turn if OFF, it will use my "Phone Ring Tone" !!! - A long MP3...
..in other words, I cannot silence it.
The phone does have a "Silent" ring tone (internally) but it is not one of the available "Notification Ringtones".
..anyone have ANY clue on this?
-Hanadarko
Create a audio file with silence in it and save it into the same folder and possibly same format as the "Droid" notification and chose it as the SD Card Notification.
