sd card problem on Huawei honour
charles31
Hi all,
I tried a Miui update via the update app and at restart, I had no more connection with my operator. Not totally satisfied by Miui, I then decided to flash ICS B926 (offical rom) to settle the problem and try. The problem is that my sd card doesn't show up on my pc on usb connection. I tried everything I found on the internet, nothing works.
Any help would be deeply appreciated.
Just one thing, I am not a geek....
Thank's in advance
Charles
Hello and welcome charles!
Sounds like you have 2 issues now? No cellular connection and no sd card recognition?
Is there a nandroid backup you could restore?
I am not familiar with that device, sorry, but have you tried a different cord?
Are your drivers installed? Can you see your sd card on the phone with a file explorer?
Thanks for answering so quickly Mikestony !
My backup is on the sd card... (original gingerbread rom)
The sd card works fine within android because data can be stored (pictures taken by camera for instance) and explorer gives relevant informations on it.
The problem is when I connect my device on my computer : I get a CD driver and 2 storages I can't open or so. However, I checked the parameters as prescripted in Huawei tutorials to allow access to the sd card...
Any idea ?
charles
