I have a dumb question. My sd card bit the dust and I have to put my apps back on my phone. I'm running MIUI and just need to know if all my apps will go to the phone or do I need to replace the sd card first?
taking pics stores on the sd card, i have never tried taking the sd card out to take a pic, it may store in internal memory, but i wouldnt think it would.
and why are all your apps going to sd card? they should be on the memory the dx has lol
My apps aren't going to the sd card. What I meen is the apps you have that rely on putting things in a folder on the sd card. Apps like TiBu. I can't use TiBu because there is no sd card to save to.
Yeah it crapped out. My phone can't format it and neither can my computer. Everything sees the card but cant do anything with it. A friend of mine had this very same problem with his OG Droid. It's cause by the cheap low quality cards they put in.
Same thing happened to me. Spent a good three days wondering why my phone wouldn't write/read it, thinking my phone was broken. Good thing is, a 16gb card is only 20 bucks on Amazon.
