sd card problems
iainw
hello all. i have put an sd ard into my s3 and transferred music from phone onto it, only thing is, half of my music has been put into a file called lost.dir and i cannot do anything with it. seems like the card hasn't recognised some. and now my phone says that it does not support the format when trying to play these ones. all was fine prior to moving to sd card. not great at this type of thing so any help would be much appreciated.
I think all you have to do is 1,go to your file app (looks like a file folder.
2 tap on it to open, then scroll to external sd folder, tap to open
3 check folders here and find one called music, if not present you will have to make one.
4 do this by tapping the button on the right of the home button at bottom of phone, tap the + create folder, then name it .
5.now go to your LOST DIR. folder tap to open, now tap bottom right button again and select more from the list select move.select all files then move,now scroll to external sd open and go to your new music folder open it and tap move here well done you should now have a usable music
