Help sd card problems!
jmenta
Can anyone please help?! I cant view pictures or do anything because it says "no sd card" when i go to my gallery it says "0 pictures insert sd card" but at the the top of the screen it keeps saying "sd card safe to remove" as soon as i remove it and put it back in it says safe to remove again. I tried putting it into the adapter and putting it in the sd card slot in the computer and when i go to my computer and try to open it, it says "file corrupted or unreadable". I also tried having the card inside the phone and plugging a usb cord into it and into the computer and that doesnt work either! this is a brand new 32 gb sd card with a couple hundred pictures of my daughter please help!
Welcome to the forms jmenta. Try putting your card back in the adapter then open my Computer and right click on the card letter. One of the options should be Tools. Run Error-checking with Automatically fix file system errors and scan for and attempt recovery of bad sector checked. After that using Tools again defragment your card.
