Help sd card question
I downloaded estrong and was looking at my sd card. My question is on my sd card there is a file called thumbs with a bunch of files in it. What is that and is it safe to delete? Thanks for your help.
Without apps2SD you can pretty much delete anything that you want off of the SD card and it won't make much of a difference. The phone itself will create folders when necessary.
the thumbs folder is were it saves all the thumbnail pictures in your gallery and such and such i beleve
