exitwounds8o8
Couple questions about the sd card for the s5.
Have a 64gb SanDisk card and I'm running into some interesting situations perhaps someone could help.
After downloading a movie or TV show for example I try to move the files from my device to the sd card. However more often then not I find that once i move the containing folder the files either don't transfer in full or the file simply stops working.
Trying to get things to download directly to the SD card as I'm sure you guys know. There really isn't a lot of space for memory on the device itself. However I can't find any settings in apps or on phone that'll allow me to do so.
Anyone run into this issue or something similar? Know s work around by any chance?
