SD card read only - cannot save to it
  • Start date Start date
A
Android Question
Guest
aRCHOS 101XS - 64 gb sd card seems to be read only. Can access files but cannot save to it - says no such path....can i change it to read/write?
Check the path. The error is telling you that there's a typo or an app has a bug. (Or the card isn't mounted,)
For instance, if the card has a directory named
/sdcard/data/myapp/
and you're trying to save to
/sdcard/data/myap/
you'll get that error. (Missing 'p' in myapp.)
