SD card reader
Parshooter
I know that the SD card reader can transfer stuff from my SD card to my pc, but can I actually see what's on the SD card, on my pc, when it's hooked up?
Of course you can. You should get prompted to view the files when you connect the card to the computer. If that doesn't happen, just click start, then computer, and it should be there labelled sd card, just click that finally and your files should be there to view.
