I am wanting to rip some dvds to a sd card, and then watch them on my 10.1 2014 tablet. Once the movies are watched, I will delete them and record new ones to the sd card. Which Sd card should I buy? Are they all the same or should I look for one with higher write/read speeds? What type of sd card would you recommend?
PS...I would also like to be able to remove it and plug it into my windows 7 machine for transferring the movies to it so I will probably need a usb adapter or something.
Thanks for any advice
