Help SD Card Removed Error
hi all
since yesterday, I am getting SD Card removed error notification. Before that notification, everything was fine. So after that notification, i removed the sd card and re-inserted it. but nothing happened. Then I removed the sd card, but still i was getting the sd card removed notification. I then connected the card to my PC with card reader and formatted it. But still when i inserted it to the mobile, i get the same error.
Has anyone else experience this kind of problem. I also want to know if this is a device error or the sd card error, as i am able to read the card in PC.
Thanks in advance!
Hi, I have been getting the same error over the last few days too. It does seem to coincide with me replacing the standard 2gb micro card with a 16gb sandisk micro card so dont know if that is the problem ot something a bit more technical.
Regards
Solution is simple.
use class 4 or class 6 sd card.
more the class,more improvement.
This isn't a solution to this problem but coincidence. See other threads where people checked back days/weeks after they have changed the SD card that they see that message again.
BTW there are a already lot of other threads about this issue.
hi folks,
At last I had to send the device to the LG Service Center, they said that the problem was because of the defect from SD Card Socked, and they will be changing it in few days(they are out of stock already!!).
I think that cause is the main reason for the problem many of us are having, I had figured it out by taking the SD card out of the device but I was still getting the SD Card Removed error. Technically, it should only show the message as long as SD Card is in the device. otherwise, I suspect it should always be hardware problem, and if someone gets it working after that just by changing a card to a new card with HIGHER CLASS, i think so that they are susceptible to such case again soon..
I'm now getting the same problem with an 8 gb hc card. I tried formatting it in my laptop, but it wouldn't go. So I'm gonna try formatting it in my phone.
Nope, didn't help.
