SD card transfer
Hi idealtag. Welcome to AF. Thanks for joining the community. There are some apps such as the photo app that will allow you to choose the folder that you save your files to. To copy or move files from the phone to SD storage I like using a file manager. You can find many at the play store that will allow you to manage your files. I use Astro but it is only one of many that will do the job for you. I hope this helps and that you enjoy your time here.
