Help Sd card trouble
koffein77
I receantly bought an ideos x5 but when i put in a external sd card sandisk micro sd 2gb. The internal sd card stops working and i cant launch apps that are installed on it and the appz icons dissaper from the phone.. Something wrong with my phone or sd card ?
Koffein77
Can you please elaborate on how you solved this problem... i am having the same issue, internal memory not visible and only memory card is showing
Thanks
