SD CARD unable to mount!
Hi
somebody please help!
I clicked unmounted, and than disk drive mode, vanished, and i have been unable to reload my sd card any please help?
Welcome to the forums dude!
Hmm try rebooting... hmm i am thinking now.
Let me know dude
Stinky :)
Ja friend just simply reboot. :)
That might fix it other wise hard format might aswell could fix it
AND if that does not work then i will show you how to reinstall the
operating system
Yes friend,
Just simply turn off then turn on again. :)
I am hoping this will fix it first... however if not
then we will have to go a bit further... i hope not.
Stinky :)
Shit.... that is not good news!
Naah don't worry about being slow
dude it's all good friend!
Don't worry about that! :)
Okay you need to hard format or reset factory settings now.
You will lose all data ... contacts, mail everything so i don't know
if you are happy with that.
Stinky :)
any way to save lol
I am sorry to say since your sd card is gone or not showing up
you have no other choice...you would have been able to back up using sd, hmm maybe you can sync with google
contacts... let me have a look for you dude :)
Hang on dude brb.
Stinky :)
