My SD card is Kingston and it's working properly when I tried it on another phone and yes the PC see it and I reformat it but I still get the same problem with my phone (VIVO Y91) it was working fine before but suddenly it disconnected and it keep saying SD card Unavailable and suddenly stuck on Reading SD Card but it take's forever and nothing really happens I also tried rebooting my phone still same problem.sounds like the card might be corrupted. what phone do you have? which sd card do you have? how long have you had the card?
does the pc see it when you connect the phone to your computer? if soi would copy its content to your pc and then re-format it.
Do you know any setting that might be blocking my SD card?sounds like the card might be corrupted. what phone do you have? which sd card do you have? how long have you had the card?
Man when I removed the SD card it says SD card removed so it means that my phone actually read my SD card but why can't I access it or see it. Any way I tried what you said but It dint work I think im just gonna go Upgrade for a new phone Thanks for the respound any way I appreciate you're timeok not the sd card. the only thing that i know of in settings is for you, is to either mount your sd card or unmount it.
if it is your phone and not your sd card, then it could be either a software or hardware issue.
if it is a software issue, try running it on safe mode and see if you have access to the sd card.
if you are still not able to access the card then the only thing i can think of is a factory reset
now if it is a hardware issue then you need to either take it in or upgrade to a new phone![]()
well i had an sd card that was corrupted. nothing was on it. it was somehow deleted or not seen by the phone or the pc. it was just gone. almost like it was reformatted, but i never performed one. the phone saw the card as well, but would not let me save anything to the card. i replaced the sd card and all was good. i unfortunately lost some photos as it never had a chance to download them to google photos on wifi.Man when I removed the SD card it says SD card removed so it means that my phone actually read my SD card but why can't I access it or see it. Any way I tried what you said but It dint work I think im just gonna go Upgrade for a new phone Thanks for the respound any way I appreciate you're time
