SD Card Unexpectedly Removed - FIX
reilus
Has anyone else had problems with SD card unexpectedly removed??
I had these problems, they were intermittent. I am still testing to make sure that my fix works, but so far so good. Here is how it works:
First, you need a decent SD card. I got some stupid junk off ebay. You need an 8GB, Class 4 card. You can get one for 20 bucks at a decent electronics store, it is worth the money.
Next, back up your old SD and then remove it from your phone and reboot the phone.
Then, Take your new SD card and put it in your computer; do not put it in your phone yet. Right click on the card, and select "format".
Once the format menu comes up, uncheck the quick format button and leave the other settings alone. It will take 20 or 30 minutes to format, but it is worth it.
Finally, move your info that you backed up onto your new SD and pop it into your phone. Wait for all the crap to refresh and--hopefully--you're done having unexpected problems with your SD card.
You don't need to do a format. All you need is a good card. That is the #1 important thing. My included card was a piece of crap and had the error probably five times a day. All I did was copy everything over to the new card and there has been no problem since.
If you're not rooted, then ignore what I'm saying because it won't apply to you. But if you *are* rooted, and you install a custom recovery, it becomes very simple to format and partition an SD card through the phone, including the apps-to-SD partition. Head over to the sub forum under this one called LG Optimus M - All Things Root if you're interested, and begin reading thoroughly before trying anything. =>
EDIT: Just saw you're running a different rom already. lol oops. Use your recovery as mentioned above, but feel free to ask if you're not sure how.
