Hello people.
As the title says i try to mount the SD card to PC but it wont happen.Phone asks if i am sure i want to format it, which i dont want
I noticed this problem after upgrading to GINGERXPERIA 2.3.7 last night, after a ROM missflash
I was on CM7 2.3.5 but i cant tell for sure if the problem existed back then cause i did everything via WIFI
Everything works great in phone and i can access the sd card via FTP client or excnage files fia ES manager and WIFI but when i plug the cable it asks to format.
Any help would be apriciated as i cant format it for any reason.I have buckups,apps etc that i cant afford to lose.
Thank you in advance!
