Sd card wont mount
billywizz
Hi there i have just bought the atrix 2 but when i insert the sd card it flashes breifly preparing sd card then clicks to you can safely remove sd card tried formating but get same thing! Also tried a different sd card but same thing happens! Thanks in advance
