Reformatting the SD card should work. You need to save all your contents of the SD card in a folder on your computer. Insert your SD card in your computer and follow these steps:
1. Click on your SD card to open it.
2. right-click and choose format card
3. make sure the card is set to format to the NTFS heading on the formating options
4. Format Card
5. Insert card into phone
6. Format your card to the phone
7. Put all your files back in your SD card!
Hope this helped!
