Help SD Card
healey6
My SD card says that I have over 7 gigs available yet when I try to move files even one at a time small ones at one or two megs from my computer to the Droid 2 I get a message stating that 0 bytes are available. Do I have to reformat the card? If so, will I lose my contact list?
You should throw the contents you want to save onto your computer, then reformat the card. At which point you can transfer them back to the card. Give that a shot.
Your contacts won't be touched by doing this and they should also be backed up at the Google servers if you've so allowed under your settings.
OK I copied everything over to a folder on my Desktop, reformatted the SD card and now I can not transfer the files back to the SD card. Surely there is a better way to handle this stuff. How do I now get my original files back as I am still getting the message that I have ZERO space even though the Android says that I have almost 7mb.:mad::mad::mad:
