Help Sd card
Putnold card in, connect to pc and copy onto pc. Put the new card in, connect to pc and copy back onto the card
I just put my SD card from my Tbolt right into the Razr. It will be identified as "sdcard-ext". The Razr seems to refer to the phone memory as "sdcard" and the inserted card as "sdcard-ext".
Its like that because of the way the internal memory is partitioned. 8 GB of the internal memory is reserved for the system while the other 8 GB is available to the user. Hence the need to address the memory available to the user as SD card and SD card-ext.
