Sd card
Which phone do you have? Knowing the model would help folk answer your question more readily.
I assume you've tried the usual method of pushing down on the card first...
Which make a model phone do you have, some you have to push the SD card in to pop out, some you have to use your nail and slide it back, and some have a little door that locks, depending on your phone them we will tell you how to remove.
Hello and welcome. ;)
I see that you've gotten some good tips on what to do. Usually, I use a tweezer to pull it out (if my nail isn't long enough) from out of the slot.
Let us know, if you resolved your issue.
