sd card
  • Start date Start date
Hi
If you have v4 onwards of Android you can't run apps from the sd card unless you root your device. Most apps have settings which allow the data to be stored on sd. You can keep downloaded apk files on sd but to run the apps they have to be installed to internal storage.
Roger
