sd card
  • Start date Start date
A
Android Question
Guest
I have a samsung 10.1 tablet. I had to completely factory reset my tablet due to an error on my part. Now i want to get my pictures off my sd card but don't know how. Can u help me? Thanks
Hi and welcome to Android Forums!
Generally, the external microSD card is not wiped in a factory reset. You can safely remove the card and put it in your computer using a slot or USB adapter.
If you're referring to any pictures or other user data stored in the tablet's non-removable,internal memory, they no longer exist as the factory reset completely wiped the tablet and restored it to brand new, out-of-the-box condition.
I hope this helps.
It’s great to have you here :)
