sd card
  • Start date Start date
A
Android Question
Guest
At the top of my samsung galaxy mega I have a exclamation symbol next to my sd card...what could this mean?
Hi, That is a generic warning that something is not quite right with your SD card. It may be corrupted or is not mounted or something similar. You should check to see if you have access to the SD card either from a local browser or via your PC browser. As a precaution,
it would be a good time to back up your SD card if you have access. A fix could be as simple as rebooting your phone. You might need to remove and remount your card. It may be corrupted and will require reformatting. Back it up if you can. Then try to resolve the problem. I hope this helps.
