sd card
  • Start date Start date
A
Android Question
Guest
i am having no luck getting anything to go to sd card. i check and nothing is being put there how can i fix ir
Copy a file to it. If it saves there, there's nothing wrong with the card. If it doesn't, either your card is bad or your phone is.
