A Android Question Guest Oct 30, 2013 #1 is there a way to see wht is on a used sd card on a samsung 3 i was able to see the space used and available but how do i see whts on the card
girolez Often Off Piste Oct 30, 2013 #2 Hi If you use a file manager program like ces file explorer you should be able to see what is on the card Roger
