Help sd mic
dkdteb
I know this has been talked about a lot, have zte n800. 4.1.2, jellybean. I have been using a 8 gb SD micro. got a 64 gb. going through instruction manual, nothing says u can't use anything bigger. NOTHING. but it doesnt let u use it. hate to use the smaller, so........ what do I do?? AND does rooting phone really help? thank you doreena
According to THIS, the maximum external storage this device can read is 32GB. Rooting will not increase this, as hardware limitations are what they are. It only has 1GB of RAM, which is very small anymore. I know this isn't the answer you were looking for, but that's what I have for you :)
