Root SD Mini and MTP Connection do Not Work After Root
Wyte1000
I have recently rooted my lg lucid 2. The process went smoothly and worked, but now my 8 GB SD Mini cannot be read or even formatted. When I try to hook it up to a computer it will freeze until the card is removed. Also when I use the device's MTP mode, it will display the directories and any files in the root folder (sdcard0), but not any of the files in the directories. What suggestions do you have to correct these problems? Thank you very much in advance.
