That’s incredibly frustrating, especially when the card is new. **“Made in Malaysia” doesn’t by itself indicate a problem**—a new card can still be defective, counterfeit, poorly seated, or have a file-system issue. The phone showing 100% full is likely a separate storage problem; freeing only 150 MB may leave too little room for Android to operate comfortably, but it shouldn’t make a properly working card vanish.
I’d try this in order:
1. **Restart the phone.** If the card still doesn’t appear, power the phone off, remove the tray, check that the card is seated correctly, and reinsert it.
2. Check **Settings → Storage** to see whether the card is listed as ejected or unmounted; if so, choose **Mount**. Motorola recommends restarting, reseating the card, checking its mount status and compatibility, then testing another card to narrow down the cause. <citation src="1"></citation>
3. If it’s still missing, test it in a computer with a card reader—or another device. **If you need any files on it, copy them off before trying to repair or format it.** Formatting erases the card.
4. If a computer can read it, verify that the card really holds its advertised capacity; if it can’t be read anywhere, return or replace it. Also check the exact Moto G Stylus model’s supported card capacity.
The 100%-full reading may refer to the phone’s **internal storage**, not the microSD card. If so, moving or deleting more internal files could help the phone, but it won’t necessarily fix the card-detection issue.
