Settings/Application manager. Press the app you want to move. Look for a "Move to SD card" button. If it's not there, the app can't be moved. If it's grayed out, the app can't be moved. If it's there and live, press it. If you're lucky the app will run from the SD card.
Once you do this, even to one app, NEVER unmount the SD card or run the phone with the SD card removed.
